Reload this Page >
BIG A-5 Vigilante build
Old 11-13-2014, 09:51 AM
  #101
sierratango
sierratango's Avatar
Spent last evening reading all the posts on this project.
You are going to need some man power and financing to do this project.
Understandingly you will be molding this project in segments/pieces, but that is a lot of material, time, manpower and money to do.
it is a huge model! A museum piece! Fabulous effort, I hope you keep at it. Wish I was close by to lend a hand. Molding of some of the boxy shapes on that plane will make some extra challenges, possibly multiple part molds. Looking forward to seeing it progress.
Old 11-13-2014, 05:12 PM
  #102
jetsrfun
Hi :
I,m keeping an eye on the progress. Looks great so far!
My stabs and flying rudder aerodynamic balanced to eliminate any flutter possibles. I worked the late Ivan Munninghoff in their locations.
I had well over a hundred flights on my prototype with never a problem. I still have the proto model hanging in my shop.
Best Regards,
Phil Nuckles
Old 11-14-2014, 06:19 AM
  #103
DocYates
My Feedback: (102)
Absolutely beautiful work. I am always impressed with the technical skill displayed by my modeling colleagues, and wish I had half their talents. This is going to be a beautiful ship.
Old 11-14-2014, 08:59 PM
  #104
jofunk
hi sierra tango,
The first model is going to be constructed of wood. If it flies someone can pick up the ball and run with it. A few people are pushing for molds and glass fuses, but for now that is beyond what I want to do.
Joe
Old 11-14-2014, 09:40 PM
  #105
sierratango
Understand, a one off is awesome nonetheless. Keep plugging away!
Old 11-15-2014, 03:13 PM
  #106
jofunk
I See Temped the bulkheads for the Vigilante fuse. I only did half to save material. They will be flipped over to trace out the whole bulkhead. I also made a short video on how to use See Temp for making templates. It really comes in handy when scratch building. I can now trace out a 1000 bulkhead sets now that I have the templates…….Not http://youtu.be/kte4DuMZRNE
Old 11-19-2014, 04:46 PM
  #107
jofunk
Vladimir stopped by to show me his progress on the landing gear. I snapped a few pictures with the mock up wood strut in a few different positions. I talked to Dave at Robart today. They will be sending out some 6" wheels and brakes for the gear. It will also help with the visualization of where everything is supposed to go. It is funny. I asked Vladimir about this or that on the gear and he tells me he is not sure yet…. He is designing the details as he builds them.
ID:	2048602   Click image for larger version
ID:	2048603   Click image for larger version
Old 11-19-2014, 05:43 PM
  #108
sc0tt
My Feedback: (61)
sc0tt's Avatar
Hey Joe, found these pics that may help your build... http://flickrhivemind.net/Tags/a5,vigilante
page 2 has some good gear shots
Old 11-21-2014, 11:10 AM
  #109
jofunk
Nice find Scott…….I traced out the bulkheads for the nose of the plane. I need to engineer room for a cockpit and a nose wheel well. I think a floor on the datum line and raise it in the wheel well area.
Old 11-22-2014, 12:44 PM
  #110
jofunk
I doubled up the plywood and nailed it together with paneling nails. I pushed the nails through and cut them off. I was then able to cut out the bulkheads along with some cut outs to create a box. # 7 needed to have the wheel well cut out but I nee to temporarily save the structure for construction. they will be separated and then scabbed together.
ID:	2049368   Click image for larger version
ID:	2049369   Click image for larger version
Old 11-22-2014, 06:02 PM
  #111
edwarda10pilot
Joe:
Really impressive work by you and your modeling buddies. Very impressive.
Ed
Old 11-23-2014, 08:17 AM
  #112
jofunk
Thanks Ed……I cut out for the box and butterflied a few of the bulkheads open. The next step is to scab them together and then start standing them up. I need to talk to Vladimir about the size of the nose wheel. well I opened it up to 3' wide x 4 1/2" deep. That is what I am going to cut out of the mating plate that he made. I know the pictures are not much to see but like the 1/4 scale Panther I am taking a picture of everything and posting it for posterity.
ID:	2049518   Click image for larger version
Old 11-23-2014, 08:43 PM
  #113
jofunk
I made some scabs and sprayed them with accelerator (the side with the marker on it). After opening everything up they got scabbed together. I stood the bulkheads up with a little dab of hot glue to get a visual of everything. The nose is almost 4 feet long. It can easily poke your eye out……..(inside joke)
ID:	2049689   Click image for larger version
ID:	2049690   Click image for larger version
ID:	2049691   Click image for larger version
Old 11-26-2014, 09:02 PM
  #114
sierratango
Looking good!
Old 12-05-2014, 03:33 PM
  #115
jofunk
Vladimir did a little more work on the main landing gear. he brought them to our club meeting so I snapped a few pictures of them for the post.
ID:	2052511   Click image for larger version
ID:	2052512   Click image for larger version
ID:	2052513   Click image for larger version
Old 12-05-2014, 03:38 PM
  #116
ps2727
Looking great, Joe,
Has he worked out a downlock?
Paul
Old 12-05-2014, 04:03 PM
  #117
Ron S
Ron S's Avatar
That's some heavy duty looking landing gear! Nice!...
Old 12-05-2014, 04:16 PM
  #118
jofunk
Hi Paul
In picture 2 you can see some extra material on the top inside of the strut. that was going to be the down lock onto that top plate, but it was in the way upon retraction. The down lock is still being brainstormed.
Joe
Old 12-06-2014, 09:45 AM
  #119
jofunk
I started standing up the nose. The plane is flat on the bottom except for the very nose and tail. The spacers on the bottom sheeting creates the curve in the nose. They are glued to sheeting and the table so nothing moves. An aircraft ply floor is glued in. It will become a box. The nose wheel well will also become a box. I also put some notches in for some stringers.
ID:	2052652   Click image for larger version
ID:	2052653   Click image for larger version
Old 12-06-2014, 09:48 AM
  #120
sysiek
My Feedback: (176)
sysiek's Avatar
Joe use laser this will help ,I think?
Old 12-11-2014, 09:44 PM
  #121
jofunk
Ill throw a laser on it Sebastian……….. Nothing exciting just started to box in the cockpit and nose gear wheel well.
ID:	2054291   Click image for larger version
Old 12-13-2014, 05:20 PM
  #122
sierratango
Default Never saw one in the flesh, here it is.
just got back from the Footlocker Cross Country Championships held in San Diego, California.
Arrived on Friday and had an hour and a half to spend on the aircraft carrier Midway.
Built in 1943, it was in service for Fifty years which means it had a lot of Naval aircraft on board from the Vietnam and Korean wars.
The A-5 and the F8 Crusader were my favorites.
ID:	2054854   Click image for larger version
ID:	2054855   Click image for larger version
ID:	2054856   Click image for larger version
Old 12-13-2014, 05:44 PM
  #123
sierratango
Default A few more photos for your other builder, F-8
Beautiful plane too.
ID:	2054861   Click image for larger version
ID:	2054862   Click image for larger version
Old 12-13-2014, 10:01 PM
  #124
jofunk
Nice pictures ST. RCU is great for sharing info…….I started to build up the hatch separation area,engineering as I go.
ID:	2054907   Click image for larger version
ID:	2054908   Click image for larger version
Old 12-14-2014, 03:52 PM
  #125
jofunk
Vladimir stopped by to drop off the main landing gear. They are pretty much done except for the actuator. I can use them as they are to start fitting them into the plane. He did a great job machining them……………..When Vladimir stopped by he asked that I tell Sierratango that he is very interested in your glider work. If you have time he would love to communicate with you about what you are doing with the molds etc.. Vladimir is a big scratch building glider nut. He has enlisted me many times to fly his tow planes to get his gliders up. Here is his profile page. http://www.rcuniverse.com/forum/members/vholis.html
ID:	2055068   Click image for larger version
ID:	2055069   Click image for larger version
ID:	2055070   Click image for larger version
ID:	2055071   Click image for larger version
