Reload this Page >
Pilot-rc PREDATOR 2.2m Sport jet / full composite
Old 09-30-2017, 05:24 PM
Fireflynightshift
Fireflynightshift's Avatar
Chrisansilver,
With the K140 at high idle she starts moving forward without even opening the throttle. I take off at half throttle with the K140. Try a smaller turbine in it first. If you going to do the 3D jet thing then by all means or stick to the grass then you will be fine. It will be a rocket. I am thinking of fitting a 16KG to do 3D, will keep you posted.
Enjoy and I wish you many happy flights with the Predator.
Have a great day
Regards
JB
Old 10-02-2017, 05:07 AM
huison2005
Originally Posted by Fireflynightshift
Some More, and remember feel free to ask if you need help with info with the build. If you build with out rushing you could finish it in about 2 to 3 days. This is the first kit that the only thing I glued is the plastic cable supports. The set that I used is same as on the Pilot RC webpage except I put in more flaps (85mm) and 2mm more aileron. All surfaces 25% expo and rudder 40%. Enjoy the flights.
Have a great day
Regards
JB
...Glad that you are here , this is my first full composite jet aswell , but as always Pilot-rc planes keep the build as simple as always....;LOL
Old 10-02-2017, 05:55 AM
huison2005
Originally Posted by DAN 73
Hello.
How much does this New ENJET 120 turbine cost?
Who sells these turbines?
Thank you,
Dan.
Please contact TONY for more info .... this turbine is from Pilot-rc
Old 10-11-2017, 02:57 PM
chrisansilver
My Feedback: (17)
chrisansilver's Avatar
My Predator shipped yesterday from Chief...
really looking forward to getting it on the work bench..
Old 10-11-2017, 03:17 PM
Fireflynightshift
Awesome news, please put some pics on as you go. Here are some more on flying..
Happy Landings
ID:	2240927   Click image for larger version
ID:	2240928   Click image for larger version
Old 10-22-2017, 08:14 PM
  #31
chrisansilver
My Feedback: (17)
Name:	IMG_3718 - Copy.JPG
ID:	2242124Click image for larger version
Name:	IMG_3720 - Copy.JPG
ID:	2242125Click image for larger version
Name:	IMG_3716 - Copy.JPG
ID:	2242126Click image for larger version
ID:	2242127Click image for larger version
ID:	2242128Click image for larger version
Name:	IMG_3717 - Copy.JPG
ID:	2242129Click image for larger version
ID:	2242130Click image for larger version
ID:	2242131Well mine arrived a week ago Friday, so its been 8 days now and its ready for flight.
The box arrived safely from Chief Aircraft and have always had good luck from Chief.
The quality of kit was absolutely amazing, fit and finish perfect in every way.
I have built Comp-ARFs, DR Hobbies, Krills and the Pilot Predator is right there with them. Everything that was pre-assembled was tore down and checked and didn't find a single issue.
The Predator balanced perfect at recommended range with the JetCat 220RXI, plenty of room for batteries and electronics to make for a neat install. The included retracts appear to be up to the task and work smoothly, time will tell.
AUW RTF dry weight 28.03 lbs.
Old 10-26-2017, 12:01 AM
  #32
chodeokha
Default First Predator jet in S.Korea
Powerbox Mercury
Vector option
Jet cat P220RXi
ID:	2242528   Click image for larger version
ID:	2242529   Click image for larger version
ID:	2242530   Click image for larger version
ID:	2242531   Click image for larger version
ID:	2242532   Click image for larger version
Old 10-26-2017, 02:33 AM
  #33
chrisansilver
My Feedback: (17)
Like the blue..
how does it fly with the 220 RXI?
hows the landing speed with the higher residual thrust of the 220?
can you tell me your setup on flaps and elevator settings for takeoff and landing?
Also where are your throws on ail, ele and rudder on flight modes.
I will get maiden on mine on Nov 16th.
Old 10-29-2017, 07:39 PM
  #34
huison2005
...finally my Predator arrived , landed safely .... no damage
ID:	2242984   Click image for larger version
ID:	2242985   Click image for larger version
ID:	2242986   Click image for larger version
ID:	2242987   Click image for larger version
Old 10-30-2017, 07:34 PM
  #35
NICKELUP
My Feedback: (82)
like that scheme. Can you please post some pics from the top and bottom of the wing. Thank you
Old 10-30-2017, 10:10 PM
  #36
Dave Wilshere
Page 1 ��
Old 10-31-2017, 01:50 AM
  #37
Dansy
My Feedback: (53)
Dansy's Avatar
post number 11.....
Old 10-31-2017, 04:36 AM
  #38
RC Larry-RCU
This is an absolute awesome scheme! Wish it was offered as one of the available schemes here in the US. I plan to order a green/black Predator in the next few weeks, but would love to have this scheme instead. Was this special ordered? If it's your own design, would you be Ok with someone else requesting it as well?
Old 11-02-2017, 03:57 AM
  #39
chrisansilver
My Feedback: (17)
Powerbox Mercury
Vector option
Jet cat P220RXi
How much fuel do you carry since your flying the 220RXI?
i have 2 options on tanks, I have a 125oz and just received my custom made tank that carries 160oz. I know the 220 burn rate is 24.5 oz per min at wide open, I figured 18oz average burn rate may be high, so the 125 gives over 6 minutes and 160oz will be 8.8 minutes. Thanks again...
Old 11-02-2017, 07:52 PM
  #40
NICKELUP
My Feedback: (82)
Very nice scheme. Thank you
Old 11-05-2017, 05:10 AM
  #41
huison2005
you can ask Tony to do this scheme , he has it ... is ok to have this scheme , glad you like it ...
Old 11-05-2017, 05:38 AM
  #42
huison2005
..... being busy this few days , finally get her test fit ...all parts fit in nicely
ID:	2243621   Click image for larger version
Old 11-05-2017, 05:24 PM
  #43
sameem83
Any flight reviews?
Old 11-10-2017, 11:05 PM
  #44
Pilot-RC
Default predator new scheme
predator new scheme
ID:	2244388   Click image for larger version
ID:	2244389   Click image for larger version
Old 11-10-2017, 11:18 PM
  #45
raron455
My Feedback: (38)
raron455's Avatar
Great looking schemes especially that Black/Orange ,but that's an Alien on the wing, the predator creature looks completely different,,
Old 11-11-2017, 03:27 AM
  #46
RC Larry-RCU
Smile
Maybe,,,,,,,,,movie,,,, "Alien vs. Predator"!!!
Old 11-11-2017, 03:31 AM
  #47
RC Larry-RCU
I really appreciate your letting me duplicate your design huison2005. I have been in contact with Tony and will be ordering your scheme very soon.
Old 11-15-2017, 07:04 PM
  #48
huison2005
... I'm so exited to start the build., seems pretty easy straightforward to build it ....
ID:	2245197   Click image for larger version
ID:	2245198   Click image for larger version
ID:	2245199   Click image for larger version
Old 11-19-2017, 01:28 AM
  #49
Fireflynightshift
http://youtu,be/5X8oZZfYK8c
Hi All
Short take off and landing with Predator, it now has a K160G2 fitted. I get 7 minutes flight with on the standard tank supplied. Awesome jet and enjoying it and I have 18 flights with so far no hassle. One out field landing due to turbine bearing frailer straight after take off on flight 4. With out a doubt it is a well constructed jet and can take some ruff landing strips no problem. Enjoy
Have a great day
Regards
JB
Old 11-19-2017, 12:14 PM
  #50
sameem83
the video is not working
