Reload this Page >
T-one models F22A Raptor scale build!!!
Old 02-13-2019, 04:40 AM
  #101
gunradd
My Feedback: (9)
gunradd's Avatar
Only have 4 and a half weeks until FLjets.... lots of work still to do. My missile racks look like will work good and I’ll start that install next along with trying to get the hidden hatch latches done. After that it becomes a normal build for the most part until I do the air system with it’s on board air pump.
Markings from Tailormadedecals are almost done. Going to start working on getting the paint. On my yellow I used a crap load of testors model master paints. I think on this one I might mix one batch and then have it matched at a paint store. Not sure. The color on the F22 is VERY challenging to get right. I might just end up doing the Modelmaster paint again since I know it’s the correct color.
gunradd is offline
Old 02-13-2019, 06:17 AM
  #102
Auburn02
Auburn02's Avatar
Nothing like a short deadline to light the fires! Can't wait to see it at Florida.
Auburn02 is offline
Old 02-13-2019, 09:39 AM
  #103
AndyAndrews
AndyAndrews's Avatar
Good luck Chris! Hope you win! Love the solutions you always come up with. Also those Strictly scale Missiles are off the hook brother.
AndyAndrews is offline
Old 02-13-2019, 10:31 AM
  #104
gunradd
My Feedback: (9)
gunradd's Avatar
Looking forward to seeing you Andy at KY jets brotha!
gunradd is offline
Old 02-13-2019, 03:55 PM
  #105
F16Jeff
Chris,
Excellent model and T1 quality to boot. I am watching your build and very impressed.
Cheers!
Jeff
F16Jeff is offline
Old 02-14-2019, 04:10 PM
  #106
gunradd
My Feedback: (9)
gunradd's Avatar
Thnx Jeff.
starting to work on the hard stuff... scratch built a moving missile rack. It works great! This thing is going to look sick when I open the doors and pop the missile out!
gunradd is offline
Old 02-14-2019, 04:45 PM
  #107
gunradd
My Feedback: (9)
gunradd's Avatar
Hidden hatch latch system worked good. I open it through the gun door. No more ugly latches 😎.
gunradd is offline
Old 02-14-2019, 05:28 PM
  #108
FenderBean
FenderBean's Avatar
Man they really over exaggerated the panels on the jet, not sure why you would do that on a scale jet. Pictures make it look much more than I originally thought. I was going to order but I would like to see the new version once they finish it.
I like the latch idea, since the nose doesn’t come off a good way to accommodate air fills and charge even.
still a cool jet, any chance for MS Jets?
FenderBean is online now
Old 02-14-2019, 05:45 PM
  #109
gunradd
My Feedback: (9)
gunradd's Avatar
probably not. It’s to far from me. I save my vacation for Kentucky .
gunradd is offline
Old 02-14-2019, 05:59 PM
  #110
FenderBean
FenderBean's Avatar
Understand, that’s why I never do Florida Jets, I’m hoping to be in Pensacola right before Ms jet so it will allow me to go. I leave here for Huntsville July 7 so gonna hit KY for the mini vacation for the move.
Old 02-14-2019, 07:11 PM
  #111
Digital Pilot
Digital Pilot's Avatar
Fender, PM Sent
Digital Pilot is offline
Old 02-14-2019, 07:58 PM
  #112
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Hey Gun,
Good to see the build thread. What is the wingspan of the F22? What is the projected weight? Site only gives you the length of 106.3 long, 2.7M.
How does the size/weight feel when compared to your old FB F15E? Does it feel smaller, bigger, lighter, heavier than the FB F15E?
FB F15E
Length:109"(2768mm)
Wingspan:74"(1880mm)
I own the F15, trying to get a sense of the size. Thanks for the feedback.
sc
skunkwurk is offline
Old 02-15-2019, 08:12 AM
  #113
ravill
ravill's Avatar
Lookin good!!
ravill is offline
Old 02-15-2019, 03:09 PM
  #114
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by skunkwurk
Hey Gun,
FB F15E
Length:109"(2768mm)
sc
wingspan is about 79 inches.
plane feels bigger then the F15 since it has so much lifting area. On the weight I have no clue yet. I would expect it to be around 50lbs dry. We will see when I get her done. Also remember I’m not at all trying to build it light with an on board air pump and the extra functions I’m adding. It just has so much wing I’m not concerned about weight.
gunradd is offline
Old 02-16-2019, 04:40 PM
  #115
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Thanks, Gun.
Keep up the good work - the F22 is looking great!
Old 02-27-2019, 05:38 AM
  #116
gunradd
My Feedback: (9)
gunradd's Avatar
I have the answer to my problems with the channels on this bird. Dirk recommended I look into the Booma RC receivers. I personally have never herd of these receivers. So I checked and WOW they are some very nice units. This receiver will expand my DX18 with servo matching reverse and all that good stuff up to 26 channels. This will let me do what I want to do on the F22. I have a cortex PRO sitting here for the F22 but I am not going to even open the box since this receiver has a gyro built in that takes weight, barometric pressure and accelerometers into account for the gyro gain. Its a very advanced unit and can be assigned to any channel. This will give me gyro steering along with both rudders horizontal stabs ailerons and thrust vectoring nozzles. Flying a 3D jet I have found a gyro on the thrust vectoring on the nozzles to work out very well. This unit also takes into account the MAH of your batteries and gives you amount left. I messed with it some last night and was blown away how easy it was to understand. I just set up a PB on a friends plane I built for him and wanted to commit suicide after I hit a wrong button and deleted the entire program in the setup wizard. This unit is nothing like that and I was easily able to run through the menus' and understand without going through the instruction books. I also have a magnetic switch for this receiver also. We are very happy to announce PacificRCjets is now a distributor for Booma and Drik has a bunch of stuff in stock now. We also have manuals on our site. Every time we are doing a build and see something we like Dirk normally tries to go out and get it. If it makes our builds better it should work for our customers also.
r
Looks like the air valve system is running behind and I might have to install that system after FLjets. This means I will be installing a normal air system with no pump and external fill valves for the time being. Time is running out. Going to be moving very fast on this plane now. She is almost ready for paint.
gunradd is offline
Old 02-27-2019, 06:09 AM
  #117
FenderBean
FenderBean's Avatar
That’s what I do Gun, when I try something new or find something that’s really nice and helpful to our hobby I try to become a dealer for it. I don’t sell anything that isn’t high quality and useless for that majority.
Old 02-27-2019, 06:10 AM
  #118
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Gun,
Booma makes great products, I turned a couple fellow pilots onto them.
sc
Old 02-27-2019, 11:27 AM
  #119
flejter1
flejter1's Avatar
r
Hi Guys,
To keep the Data straight on this RRS unit. This unit was built special for us to include the Gyro and 6 channel sequencing and will also be available shortly to all Spectrum users. Normally the RRS unit does not have the Gyro or sequencing built in like the ARXL unit. This unit gave us the capabilities to just plug in the 4 satellites and no need for an actual receiver to be used, but gave us the ARXL functions. The ARXL, multi protocol unit (select your radio protocol) includes the gyro, sequencing etc but will require at least a 8 or 9 channel Spectrum receiver with 2-3 satellites to operate as the receiver will regulate the voltage to the satellite receivers. I am very impressed with Booma RC's products and was very fortunate that Booma let us become a Dealer. The technologies that are being used in Booma products seems to be far superior to other products currently used. Kris mentioned some technical features about the gyro, I just wanted to add it also has automatic gain control so there is no need to set up gain modes as the unit will self adjust based the jets needs at that time. It will adjust for high speed, slow speed, 3D and landing gains. Our shipment of products should be arriving hopefully next week and you can find all the information on our website including many other cool products they offer. Like Kris has mentioned on how easy the unit was to set up, you can find numerous "HOW TO" tutorial videos on youtube as well. Keep the build pictures coming Kris!!
Dirk
flejter1 is offline
Old 03-01-2019, 05:23 AM
  #120
gunradd
My Feedback: (9)
gunradd's Avatar
Been too busy to update but it’s going together!
I decided for the air system to use an old school servo operated valve for the canopy so when the plane is off it stays open. Rest is electronic valves. Will post pics of it after the weekend.
Also the painting process has begun😭. The F22 is a huge pain in the ass to paint. Probably won’t go over each little step since almost everyone will get an ARF or a PnP.
The edges get painted first.
gunradd is offline
Old 03-01-2019, 09:11 AM
  #121
Smokeyr67
Got the nose steering servo installed and installed the nose gear tonight. She is on her feet now. I also attached the nose section and filled in the gap so you can’t see it.
That image looks so realistic at first, and second glance!
Smokeyr67 is offline
Old 03-03-2019, 01:02 PM
  #122
gunradd
My Feedback: (9)
gunradd's Avatar
Base coat is on. Radio all programmed. The new receiver is fantastic! Was easy sequencing everything. Stuff is moving pretty fast now.
Got 2 more weeks to go. Still waiting on the markings to show.
gunradd is offline
Old 03-03-2019, 01:39 PM
  #123
sysiek
My Feedback: (176)
sysiek's Avatar
Looking great 👍,wish to be there at the Florida Jets to see her in person,oh well Kentucky will work to.
sysiek is offline
Old 03-03-2019, 03:12 PM
  #124
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Gun, have they released any photos of the production version to see how the panel lines have been reduced?
Gary
Viper1GJ is offline
Old 03-03-2019, 04:12 PM
  #125
gunradd
My Feedback: (9)
gunradd's Avatar
Gary I believe it will be out later this month. Also the horizontal stabs will have a quick release system on the production birds. We have them making some other small modifications also for a better aircraft.
gunradd is offline
