Reaction ARF - PST/BTE All-Composite Sport Jet
My Feedback: (21)
RE: Reaction ARF - All-Composite Sport Jet
I have a question about the gear for the composite. Will it be ok for grass fields? The wood reaction with the shorter robart struts has made a great reputation for its ability to handle rougher grass fields. Will the PST heavy duty struts, mounts and wing/nose supports be capable of the same? I'm not talking flying off cow pastures, just the "average" flying field.
thanks!
Zonk
thanks!
Zonk
Although we have not tested the gears to the limit just yet, the wing/nose landing gear mounts constructions are strong. The landing gear struts are machined from solid aluminum block. IMO, I don't see any reason why the Reaction ARF won't be able to handle grass field just the same or better than her build-up sister. We will do more testing this coming Sunday.
Kraivuth S.
Kraivuth S.
My Feedback: (21)
Thats what made me be bring up my question. With the long strut and the small wheel on the nose it looks a bit spindly to me for grass use. Will there be room to adapt a 3" wheel/possibly shorter strut to improve the "grassability" of the plane. Function to me in this regard is a concern and overrules looks.
thanks again
zonk
thanks again
zonk
#31
Our nose wheel will be spring loaded to lean back during taxi and take-off. This offset increases nose steering stability. I think you can fit 3 in wheel...will check.
Ehab, coming in on Wed afternoon? see you man. Look forward to another Sunday flying...get your Reaction ARF ready..
Kraivuth S.
Kraivuth S.
#32
My Feedback: (21)
ORIGINAL: B777
Kraivuth S.
Kraivuth S.
take care
zonk
#33
My Feedback: (44)
ORIGINAL: B777
Kraivuth S.
Kraivuth S.
#35
Performance wised, there is no restriction on the nose wheel size. Main wheel base is wide and ground handling is very good. The restriction would be the physical fit and that will depend on which nose strut are you using. PST nose strut will allow nose wheel from 2 to 3 inches.
We tested the Reaction ARF with 28lbs thrust turbine this past Sunday and she was ballistic. However, we still recommend 14-19 lbs turbine for Intermediate or entry level.
Cheers, Kraivuth S. [8D]
#36
My Feedback: (44)
ORIGINAL: B777
#37
Ehab, thanks for the amphibian test. We will brighten the runway edge light when you fly next time. Note: Runway is the paved dark surface, not the soft green rice field
Cheers, Kraivuth
Cheers, Kraivuth
#39
to kraivuth and ehab,
can you post a few pictures of the model disassembled?.....i'd like to see how it breaks down for transport in my little car.....also. a few pics of the turbine / radio install would be nice too.....i like the fact that this model has a 2 piece wing.......
thanks,
richard
thanks,
richard
#40
My Feedback: (44)
If we fly this weekend, I'll take some shots. There is plenty of room for almost anything. I will be adding smoke to mine. The two wings are joined by two aluminum spars and then they are bolted to the bottom of the fuse. I'll include a pic here showing the canopy hatch..
#41
The nose can be removed. The wing is in 2 pieces joined together by aluminum tubes. The stab/elevator and vertical fins must be glued in. Clear canopy is provided together with cockpit tub.
Pictures below. I placed the JR PCM10X along for size reference. Cheers, Kraivuth S.
#43
Dean W. at HeliJet and Bruce Tharpe at BTE will be handling the North America distribution PST and Dealers will give full support for world-wide distribution.
Cheers, Kraivuth S.
Cheers, Kraivuth S.
#46
ORIGINAL: Jeremy_D
That Looks Great!! Is there an airbrake on it as well?
There is a speed brake in the center fus just below the intakes.
cheers Pete
#50
We will not be at the Toledo show on April 4,5,6. However, we will be at Top Gun 2008 Lakeland Florida from April 23-27. For North America, first shipment will go to Bruce at BTE. As for order, please contact Bruce at BTE or Dean Wichmann at HeliJets or direct to PST Jets.
Cheers,
Kraivuth S.
Cheers,
Kraivuth S.
