Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 07-07-2014, 12:02 PM
  #326
vatechguy3
what did you end up doing for a muffler Chris?
and what props have your tried and liked with the 55RA?
i'm looking for something to go fast, maybe a 22x12 2 blade?
thanks
tony
Old 07-09-2014, 11:57 AM
  #327
vatechguy3
has anyone considered or used the Tactic TSX57 servos for ailerons, flaps, elevators and/or rudder?
thanks
tony
Old 07-09-2014, 04:27 PM
  #328
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Warbirds with a gasser can vibrate quite a bit. I pretty much use Hitec 645MG or 625MGs for the primary flight controls. No idea how good the Tactic servos are.
Old 10-30-2014, 04:09 AM
  #329
Shaun Evans
Shaun Evans's Avatar
Hi,
Has anyone tried the Hangar 9 tail unit on the TF Corsair?
Old 11-04-2014, 08:55 PM
  #330
Shaun Evans
I guess not....
Old 11-05-2014, 12:18 AM
  #331
Chad Veich
My Feedback: (60)
Originally Posted by YellowAircraft
Hi,
I'm sure somebody must have tried this by now. I don't see any reason it could not be made to work in the TF airplane and I will certainly be looking into it when I build my TF bird. Assuming they are still available when that time comes! Maybe I should buy one now and put it on the shelf just in case.
Old 11-05-2014, 07:43 PM
  #332
Duplicator41
Duplicator41's Avatar
I did see a post about someone using it on the big ESM F4U and liking it, just can't remember where the post was. That model is the same size as the Top Flite GS.
Cheers,
Andy
Old 12-11-2014, 12:27 AM
  #333
Shaun Evans
Hi,
I ended up getting one from Earl Aune. Very nice man.
Old 12-11-2014, 02:33 PM
  #334
Duplicator41
Hi,
And he makes good stuff.
Cheers,
Old 12-21-2014, 12:28 PM
  #335
Shaun Evans
Hi,
I'm gonna start this build soon. I can't decide whether or not to strip and glass it, or just iron out this lousy covering, then paint the 3-tone scheme over the covering. I got out a wing and an xacto and almost started stripping. I figured that would take the indecision out of the equation, but I couldn't bring myself to do it yet. All that sanding and I'm still just skin and bones from last summer....
Old 12-21-2014, 01:43 PM
  #336
DLEVETT
My Feedback: (13)
I too have struggled with this decision in the past.
The only time I have had success with painting over iron on covering was when I pretreated the balsa with Balsarite prior to covering the airframe.
Each time I have painted over plastic covering that I haven't put down myself (even with ironing it down)
I have been less than impressed when the plane gets placed outside in the sunshine a few times and starts to bubble.
It really makes for a disappointing look.
Now having said that, I have tried the John Redman approach with a light misting on flat clear Lusterkote over Ultracote with a degree of success.
I guess it can depend on how extensive the paint is on top of the covering.
Dave
Old 12-25-2014, 06:17 PM
  #337
vatechguy3
Got one of these for xmas today!
Going with robart electric retracts.
Not sure on servos. Maybe futaba 3305s, maybe something stronger like 9157s. Maybe overkill in this plane, but i could use them in a future bigger plane.
Have a DA50, but thinking about an eme70 twin. Anyone know if it will fit??
Tony
Old 12-26-2014, 05:56 AM
  #338
SWORDSN
My Feedback: (13)
Tony
Not without major cowl cutting
Old 01-03-2015, 11:19 AM
  #339
vatechguy3
Anyone have cockpit kit options other than the iflytallies super expensive kit and the cheap plastic top flite kit?
Tony
Old 01-15-2015, 07:51 PM
  #340
Shaun Evans
Hi,
This question is for any of you who've installed the Earl Aune tail gear. Did you have to cut the the main tail former in half back there to get the tail gear unit to be able to go through its stroke? Looks like a lot of hacking.
Old 01-15-2015, 09:41 PM
  #341
Chris Nicastro
Chris Nicastro's Avatar
@ Tony
So sorry to leave you hanging. I hope you got an answer by now elsewhere.
I had the stock muffler welded and its been fine ever since.
As for me I tried various props but the DLE 55 RA seems to like a 22x10 Xoar wood and carbon props. I used Top Flite Power Point, Zinger, and Xoar and noticed the best performance from two Xoar props.
What I liked was the prop kept the engine slighly loaded in dives at idle. The reeds stay slightly open and there is no hesitation just smooth power as throttle is applied.
I dont have a top speed number but my Corsair was faster than the TF FW 190 with the same engine.
Old 01-19-2015, 02:45 PM
  #342
handt
My Feedback: (26)
Maiden my Top flight corsair Sunday it few like it was on rails very happy DLE 55 nice power.
Old 01-19-2015, 06:14 PM
  #343
miker49
anyone know where i can find those laser cut wire guides chris nicastro used on page 11 for the functioal cowl flaps? sure would be a bit easier with some of those.thank you
Old 01-19-2015, 08:57 PM
  #344
Chris Nicastro
Those are wire guides Stratotanker makes for remote antennas. If you want some PM me and I can help. Otherwise just use strip stock cut to length and drill a hole.
Old 01-19-2015, 08:58 PM
  #345
Chris Nicastro
Cool! Its a nice flyer for sure. What prop did you use?
Old 02-27-2015, 12:57 PM
  #346
JeffH
My Feedback: (43)
Does anyone have a set of the wheels that came with the Giant Scale Corsair ARF they want to get rid of? They are out of stock until late March. I need a set for another project and these wheels are just right. Thin and 4.5" diameter.ThanksJeff
Old 02-28-2015, 08:49 AM
  #347
Warbird Man
My Feedback: (95)
As a matter of fact, I do. Still in the plastic bag. Send me a PM
Old 02-28-2015, 09:37 AM
  #348
JeffH
My Feedback: (43)
PM sent. thank you
Old 04-18-2015, 02:02 AM
  #349
Lifer
Lifer's Avatar
Does anybody have the dimensions of the removable wing panels?
Thanks in advance.
Old 04-18-2015, 11:00 AM
  #350
John Taylor
My Feedback: (16)
Lifer, I just measured my F4U ARF wing panel, and here are the dimensions. 27 1/4 long 18" wide. hope this helps. John Taylor Corsair Brotherhood #96
