Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 06-24-2017, 12:35 PM
  #426
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Stingray,
Sorry for the delay in reply. I don't know if I have the part # anymore as its been a long time since I built my corsair. It's possible they don't make it anymore or maybe I made a typo. You should be able to use any door cylinder from a 1 to 2 inch stroke. Its more of a matter of geometry or where you mount it to get the doors to open and close at the desired spots. A 1-5/16 to 1-1/2" stoke should be fine.
Just an FYI. Keep in mind you want abit of pressure on the doors when they are closed. Reason being, You'll set everything up with the wing upside down and then once you flip it over, you find the doors hang open abit. Also check all your cylinders for leaks "before" you install them. Saves alot of headaches down the road when you find the systems not holding air pressure. Most of the time its a cylinder leak.
Old 06-25-2017, 06:43 PM
  #427
stingray528i
Warbird
Thanks for the reply. I actually found the BVM 1 5/8 cylinder with 1" stroke at Dreamworks rc, on BVM they only list them on their stroke. And I hear ya on those air leaks, this is my second warbird so I had my pneumatics initiation on my Mustang , oh what fun
Old 06-26-2017, 08:14 AM
  #428
stingray528i
Ok I have a question for yall , when I first got my Corsair I originally was not going to install the gear doors but when I started to install the gear well covers it just looked like hell and changed my mind to install the doors, but the next issue is I had bought the Xicoy V2S electric valve and to use it I would have to get another V2S and a electic sequencer and module to program it. That is what 2 people at Dreamworks recomend, But I think a UP3 should be fine and simpler and cheaper. So any opinions welcome
Old 06-26-2017, 07:14 PM
  #429
BobH
I like the Ultra Precision valves. I have several of them and they all work fine.
Seems to me that if you have one you should use it..
Old 06-27-2017, 05:53 AM
  #430
stingray528i
I don't have the UP3, at least not yet
Old 07-09-2017, 02:48 PM
  #431
stingray528i
Ok, I got the BVM cylinders and the UP3 valve installed and the system works great. I really like that the UP3 has ports for both sides so you don't have to use a bunch of tee's to get the job done. So I will tackle mounting the cowl now, I just might finish this bird one day.
Old 07-12-2017, 12:24 PM
  #432
rt3232
Hi guys hope you don't mind an old guy from the vary old group build from following along, and maybe asking question now and again.
Cheers bob t
Corsair Brotherhood #6
AMA13377
Old 07-12-2017, 01:36 PM
  #433
tailskid
My Feedback: (34)
tailskid's Avatar
No one will complain...and welcome abroad!
Old 07-16-2017, 06:32 PM
  #434
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
I have finally got one of these fine birds. I got it from one of the older gentleman in my club. First things I've done is replace the stock cowl. Also put a 24" xoar on in. It has an older brison/ sachs 70cc on her
Old 07-18-2017, 12:51 PM
  #435
SWORDSN
My Feedback: (13)
Do you think the 24 prop will be close on the ground clearance? I use a 22 and its close.
Old 07-18-2017, 01:41 PM
  #436
Lifer
Lifer's Avatar
I've used a 23x8x3 on mine and didn't cut any grass. It will work but I'd say stay on the elevator.
Old 07-18-2017, 01:45 PM
  #437
jagdpanther9
jagdpanther9's Avatar
24x12 xoar is working great on mine with the FG90. REALLY liking this model and i should have video one of these next times out.
Old 07-18-2017, 10:23 PM
  #438
jagdpanther9
hey guys, this thread has been great help for me and my build so here is a little shake down of my TF giant ARF,powered by a saito FG90 R3. after 1 gallon break in on the test stand and a valve adjustment @ 1/2 gallon it is swinging a xoar 24x12 prop and has a keleo exhaust ring. the stock fuel tank gives 7 min flights and comes in with 1/2 tank left! i use a 2200mah 2s LIPO fpr the ignition and i use the castle 10 amp bec set @ 6 volts for the RX with another 2200mah 2s lipo. the retracts are robart electrics and they run off a 1500mah 2s lipo which run them just a little faster than the life did. the only issued i had with the electric retracts so far is that they both had loose fasteners so i used blue locktite on all fasteners and lubricated all moving surfaces. they are very smooth and quieter after i lubricated the screw shafts and other points. i used HS 5645 digital servos all around with the futaba 7008 rx. "SKY BOSS" graphics are from callie and the cowl is from fiberglass specialties.
this model with the FG90 is an ANIMAL! @ some point i will post video =)
ID:	2224974   Click image for larger version
ID:	2224975   Click image for larger version
ID:	2224976   Click image for larger version
Old 07-19-2017, 12:56 AM
  #439
jagdpanther9
this will give you an idea of how the FG90 will fly this model. : )
Old 07-19-2017, 03:43 AM
  #440
SWORDSN
My Feedback: (13)
Great job,assembly and flight
Old 07-24-2017, 03:20 PM
  #441
Me410
Default crash repair
Hi Guys
Had a crash this weekend with my Corsair. I don't seem to have the plans or manual any more as it been a few years since I built it.
Does anyone have templates of the wing ribs they can scan and e-mail me?
Counting from the outter wing tip I could use templates 5, 6 , 7. I know these are not the numbers the plans list, but that's all I have to go by.
Or maybe they are on line somewhere?
Tom
Old 07-24-2017, 03:29 PM
  #442
Me410
Default oops
Sorry, I see I was in the wrong form. My plane is the TopFlite Giant scale KIT.
I will fine the correct form.
Tom
Old 07-24-2017, 09:48 PM
  #443
camdyson
camdyson's Avatar
Default Elevator flutter
For anyone interested/concerned about elevator flutter on this plane, I believe I've come across a major contributing factor.
I've stripped the covering off mine and removed all the hinge points ready for glassing. Turns out the elevator actuating arms (?) are hinged with the pivots inset deep into the tailplane trailing edge. The elevator hinge points obviously pivot just behind the tailplane, so the hinge line and the elevator actuator are rotating on completely misaligned centres.
It's impossible for an elevator actuator, glued into the elevator, to rotate without wanting to move in/out or up/down within the elevator drive hole. Over time this will just tear open the elevator creating a sloppy fit, and inevitable flutter.
I've decided to simply run the pushrods out of the fuz on each side to conventional horns, to avoid the issue. Bad design flaw by Topflite!!!
Cheers,
Cam D
Old 07-25-2017, 03:27 PM
  #444
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Got my maiden done plus two. What an awesome flying plane. She took 2 clicks of up and she was trimmed.
ID:	2225648   Click image for larger version
ID:	2225649   Click image for larger version
ID:	2225650   Click image for larger version
Old 08-07-2017, 11:20 AM
  #445
stingray528i
Originally Posted by tailskid
Were you guys satisfied with the ARF's technique for securing the cowl?
Jerry
what a PITA, are yall using the silicone rtv to glue the cowl per the manual, never been a fan of rtv, I think I'll use epoxy
Old 08-09-2017, 05:25 PM
  #446
stingray528i
A couple of pics of cowl to see what y'all think before final glueing
ID:	2227522   Click image for larger version
Old 08-09-2017, 08:02 PM
  #447
tailskid
My Feedback: (34)
tailskid's Avatar
Engine is nicely centered!
Old 08-12-2017, 10:07 AM
  #448
stingray528i
I didn't like seeing the wood thru the holes in dummy engine so I painted the firewall and inside of the cowl with semi gloss black
ID:	2227727   Click image for larger version
ID:	2227728   Click image for larger version
Old 08-12-2017, 01:40 PM
  #449
Lifer
Lifer's Avatar
Pardon me if you already stated this, but is that an EME 60?
Old 08-12-2017, 06:14 PM
  #450
stingray528i
yes EME 60
