Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 05-09-2018, 06:51 PM
  #576
Chris Nicastro
Chris Nicastro's Avatar
I’d suggest not to go with 4 blades unless you drop down to 22 inches. A 22x10x4 could be close to a 23x12x3 but only testing will tell. It would be less expensive to just buy the Vario prop than experiment with several 3 or 4 blade props.
The Vario 24 inch scale 3 blade set by RPM will be very good.
The cool thing is replacement blades are cheaper than a new prop.
Old 05-10-2018, 10:24 PM
  #577
rafim
Default Saito FG60
Anyone have a Saito FG60 r3 on this plane. Is the power adequate.
Old 05-11-2018, 02:20 AM
  #578
rowdog_14
rowdog_14's Avatar
I questioned that too. This is a video I saved last year of one with it. To me it flies it scale and not enough in reserve for my flying field. If I had an open field like that I would probably do it.
Old 05-11-2018, 05:19 PM
  #579
rafim
Thanks rowdog! You see the Saito FG 60 r3 pulling a Hangar 9 Corsair with quite some authority in this video. I am sure there is some piloting skill involved but also makes me think that the FG60 will be just as good or better on the bit lighter TF Corsair. Can anyone testify to this?
I need to have 10 posts before I can attach a URL link on the post. So Unfortunately I am having to only provide the address for the YouTube video for you to copy and paste.
youtu.be/70FfT1HK4Ho
Old 05-11-2018, 05:28 PM
  #580
rowdog_14
rowdog_14's Avatar
Yeah that one looks to be pulled better with the FG60. The other guy must have it with a bad prop combo.
Old 05-11-2018, 06:34 PM
  #581
jagdpanther9
jagdpanther9's Avatar
i talked with a guy who was very pleased with the way his FG60 flys his TF corsair and i believe he said that the factory cowl fit the FG60. i know that the FG90 is nearly silly power on mine. Does anybody remember where to get the scale aluminum wheels for the 50cc corsair? i thought there was a set that would fit the robarts on either the H9 or the TF corsair. any help would be great.
Old 05-11-2018, 09:55 PM
  #582
Chris Nicastro
Default Wing bolt update
Old 05-11-2018, 10:13 PM
  #583
Chris Nicastro
Last week one of the wing bolts stripped as I tightened it to fly. The spar is aluminum an you are torquing the wing bolts every time you assemble the plane so eventually to wear out the aluminum.
This is a thread in style brass insert you can buy through Mc Master Carr. So I upgraded to M3. Now instead of about 1/8 inch of thread engagement in aluminum there’s about 1/2 inch.
I drilled the wood out in the wing, the counter bore, to the aluminum spar. With thin CA I wicked some into the wood just before screwing in the insert.
Old 05-11-2018, 10:17 PM
  #584
Chris Nicastro
Silly power? That’s what the left stick is for!
Robart makes the wheels too. The H9 set was painted white. You can buy the H9 wheels or go to the Robart site or the Tower Hobby site.
Old 05-13-2018, 08:40 AM
  #585
jagdpanther9
Thanks chris,i like silly power most of the plastic wheels have not held up well with my 30cc and larger models. although the aluminum wheels are expensive i think they will be a nice upgrade.
Old 05-13-2018, 05:44 PM
  #586
Chris Nicastro
I still have the first set of plastic wheels and foam tires on my Corsair actually. All I had to do was replace a screw/nut that fell off once. Pretty durable and look ok. I like the aluminum wheels with the machined details but they are heavy. I have a Robart set for a P-51, looks cool.
Old 05-13-2018, 06:35 PM
  #587
jagdpanther9
these corsair wheels seem to be holding up ok so far but i had one fail on my TF FW190. the plastic hub shattered on a hop while landing causing it to go on its nose and broke a prop. maybe they have these corsair plastic wheels sorted out. the aluminum wheels look sweet but they are pricey. i think ESM had a set that were a little more affordable.i looked @ VQ but i dont think they stock them any more.
Old 05-14-2018, 07:36 PM
  #588
Chris Nicastro
The best FW 190 wheels I have seen, and own, are from Sierra. Machined aluminum with simple details and good looking tires for the most part. Again, pricy, but worth the scale look.
I think it’s hit or miss with the stock TF wheels on the giant scale planes.
Old 05-15-2018, 08:20 PM
  #589
Chad Veich
My Feedback: (60)
If you guys want a Corsair wheel that is both very scale and light then I may be able to help out. I have several customers for whom I have designed 3d printed wheel hubs, Corsair and Skyraider thus far. They are 3d printed from nylon and have proven to be very durable while in use on 35-40 pound Ziroli designs. The Corsair wheels are designed to fit the 5" diameter tires available from Robart. They are not cheap, the price is probably very similar to that of a nice set of machined aluminum wheels. However, they are more scale than anything else currently on the market and they are lighter which is a nice bonus on an airplane where the gear is retracting aft. Food for thought anyway. These would be suitable for Hellcats as well.
Old 05-29-2018, 01:20 PM
  #590
handt
My Feedback: (26)
Top Flite Giant F4U Corsair Gas ARF 50-55cc,86.5"
Tower Stock# LXATDZ • Manufacturer Stock# TOPA0704
★★★★★★★★★★4.9 out of 5 stars. Read reviews.
4.9
7 ReviewsThis action will navigate to reviews.6 out of 6 (100%) reviewers recommend this product
7 questions and 6 answers for this product
Write a review. This action will open a modal dialog.
Ask a question
  • Click image for larger version
Size:  1,013 BytesWARNING: Drilling, sawing, sanding, or machining wood products generates wood dust and other substances known to the State of California to cause cancer.
Tech Notices:Notice 1 Notice 2
Shipping Note:$59.99 Surcharge
Share This Item
Discontinued
Old 06-20-2018, 06:10 AM
  #591
rowdog_14
rowdog_14's Avatar
I purchased a TF GS Corsair last year and got another wing set because I thought I had damaged the one that came with the ARF. If anyone needs a wing set let me know.
Old 06-26-2018, 10:54 AM
  #592
TJC333
Attachment 2260718
4.9
Ask a question
ID:	2261121Attachment 2260723WARNING: Drilling, sawing, sanding, or machining wood products generates wood dust and other substances known to the State of California to cause cancer.
Tech Notices:topa0704-tech.pdf topa0704-tech2.pdf
Share This Item
Attachment 2260724
Attachment 2260725
Attachment 2260726
Attachment 2260727
Discontinued
Tower Hobbies discontinued this plane which was a big surprise. I checked the Top Flite website and I did not see any indication it was being discontinued unless I missed it. Is there a replacement coming??? Would like to see this same ARF available with a dark blue high gloss finish like the Hangar 9 version but without the white ring on the cowl.
Just checked the Top Flite website again and it says "unavailable". Strange it says that rather than discontinued. Maybe that means it will be available again in the future. Who knows.
Old 06-26-2018, 06:30 PM
  #593
Chris Nicastro
@TJC333
The Hangar 9 60cc Corsair is the replacement because of the acquisition and merger between the two companies. They must have felt the need to curb the TF model due to competition between the two products/brands. Brand loyalist’s will be pissed about this. People can argue the TF model flies better, I do, but Horizon will prefer to support their house brand every time.
Old 06-26-2018, 06:37 PM
  #594
Chris Nicastro
I would not suggest it. The plane does fine with the 84 or 90 but the 60 is too small. It’s power is like a DLE 35 @ 4.4HP.
The 84 is more like a DLE 55 @ 5.5 HP but the extra weight makes the verticals and big loops slightly less impressive.
If you must have a radial I’d suggest the FG84 or 90 otherwise the DLE 55RA was an awesome light weight combo.
Im taking out the FG 84 and replacing it with a DLE 61 for more top end performance and a slightly lighter combination.
Old 07-03-2018, 08:26 AM
  #595
TJC333
Originally Posted by Chris Nicastro
@TJC333
I hope the Top Flite P51 does not get discontinued in favor of the Hangar 9 Mustang. I have read about too many problems with the Hanger 9 Mustang like wing failures, etc.
Old 12-07-2018, 10:13 AM
  #596
TJC333
I am considering building this plane however I don't like the covering material and plan on changing it to glossy dark blue. The problem is I will have to paint the canopy and cowling. I know I can get matching paint by going to an automotive paint shop with a piece of film covering and they can put it in a rattle can for me. I don't have a paint gun. The question I have is will the auto paint be compatible with the plastic canopy and the cowling? Not sure what the cowling is made out of. Auto paints used to be rather harsh on plastic however modern paints may have solved this problem.
The Hangar 9 60cc Corsair has now been discontinued.
Old 12-07-2018, 12:38 PM
  #597
ForcesR
Tower Hobbies has the H9 60cc Corsair listed as "Order Pending". They also have the TF 50cc Corsair listed as late "December 2018 Delivery".
Old 12-07-2018, 04:01 PM
  #598
Chris Nicastro
Yeah Tower shows order pending but HH shows Discontinued. The TF ARF is still available.
As for paint, TJC333, Take the new covering, dark blue, you have and have it matched at an auto paint shop. They can also give you advice on the type of paint to use and they should be able to make a rattle can for you. At the very least you can get a pint of paint to match.
The cowl should not be a problem to paint with Upol Urethane primer if you sand it down first. That will give you a good base to paint it easily with something from the paint shop. Your looking for single stage paint so it has a glossy finish when dry like the covering. On the canopy it can be tricky because its not really polycarbonate its more like PETG. The Upol primer will be ok if you apply it lightly and apply a couple coats.
I went down this road trying to use Top Flite/Monocoat products which was a huge disappointment because they don't match the paint to the flat blue covering. So I used Tamiya lacquer on my cowl and its darker blue, closer to real, but passable and I hate it. I'll be changing that for next season or so. I want to paint the plane after glassing it all.
Maybe, big maybe, you can use gloss dark blue Monocoat and Top Flite Gloss dark blue paint. I think those should be a closer match right off the Tower website rather going down this custom paint road.
Old 12-08-2018, 11:43 AM
  #599
rowdog_14
rowdog_14's Avatar
So I just got my Robart 148-E in a few days ago and they do not drop right in. Did anyone have to cut their up a little to get it to drop in. Seem I need to cut out about 2 or 3 mm or so. Also seems where the bolts go on the wood need to be longer.
Old 12-08-2018, 06:57 PM
  #600
rowdog_14
rowdog_14's Avatar
Just sanded off a few mm on the front of the retract housing wood and had to smooth out one of the dowls on the rails that was blocking it from dropping down too. Forgot to order the Locking Actuator Extensions .
