Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 04-27-2019, 05:10 AM
  #651
Saillfish
My Feedback: (17)
Looks great Chris. Where is the air filter from on the DLE
Old 04-27-2019, 08:52 AM
  #652
Chris Nicastro
Chris Nicastro's Avatar
The velocity stack or trumpet was from Aeroscale and then I added the screen later. It’s aluminum expanded metal material for crafts from Hobby Lobby. I used high temp automotive silicone to bond it on there.
Old 05-03-2019, 05:32 PM
  #653
dusturbd
​​​​​started some of the recover
Old 05-07-2019, 09:10 PM
  #654
Chris Nicastro
Two tanks run at about 3500rpm so far, so good! It ran for 20 minutes on 25oz so I’m pretty sure 10min fast flights are no problem! New engine maiden flight soon!
Old 05-17-2019, 05:03 PM
  #655
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
She flys again
Old 05-19-2019, 10:56 AM
  #656
Chris Nicastro
Looking good!
I just rebalanced mine and I’m getting ready to fly it again too.
Just FYI, DLE 61, Jtec Pitts style muffler for TF planes, stock cowl with dummy radial, required 2 pounds 3 ounces to balance at the wing spar, dry, gear up.
I’ll post pics for reference.
I finally changed the wheels to 4 inch gray wheel Dubro’s I happened to have in my box of stuff. Should be 4.5” but I went for light weight.
Old 05-19-2019, 10:59 AM
  #657
Chris Nicastro
@droppedgmc
can you show how you set up your gear doors please?
I’ve been debating air or mechanical. My air retracts have been so reliable I’m inclined to just go with air.
Old 05-23-2019, 07:33 PM
  #658
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Originally Posted by Chris Nicastro
@droppedgmc
Old 05-23-2019, 07:42 PM
  #659
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Still
have to paint wheel wells
Old 05-23-2019, 09:32 PM
  #660
Chris Nicastro
I see you went with the servo set up. How is that working for you? Any issue with vibration or stripping servo gears?
You have air retracts and servo doors right? Did you set up the sequence in your radio?
I did a dual micro servo controlled cowl flap mod and the vibration and heat messed with those servos. I upgraded the servos but I still had issues with vibration and heat wearing out and breaking the assembly. It looked great for a season then I scrapped it.
Old 05-23-2019, 09:40 PM
  #661
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Working great. I spent a lot of extra time setting them up and a lot of gear swings
Old 06-10-2019, 06:51 PM
  #662
jagdpanther9
jagdpanther9's Avatar
have you guys heard the rumors about the TF giant corsair ARF being available in the near future? i see that tower is accepting pre-orders . i have also heard from a reliable source that a non covered version is going to be available as well ! =D
Old 06-12-2019, 10:34 PM
  #663
Chris Nicastro
‘I’ve seen the group of GS war birds listed as RTC which I think is great, not cheaper if you consider the cost of covering film, but if you like to glass and paint that’s the ticket.
‘Are you saying there’s a larger giant scale Corsair in the works?
Old 06-13-2019, 07:38 AM
  #664
jagdpanther9
nope, same model just RTC.
Old 07-29-2019, 03:22 PM
  #665
Dsa44
Default Outer wing attachment
Glad to find this forum and hope it is still active. I was lucky enough to find a great condition F4U and have figured out most of the previous owner's build and setup. But need help in properly securing the outer wing panels to the center sections.
As you can see, the top of the outer panel has 2 bolt holes fore and aft. The bottom of the outer panel has 2 bolt holes side-by-side.
The top of the center section supports has a small hole thru the cf rod, and an indentation on the alum. spar.
The bottom of the center section supports has again, the hole in the cf rod, and 2 indentations on the alum spar.
The bolts that came with it are 1 inch with a thin neck and 3/4 inch and seem to be same head size. The black bolts are also 1 inch.
None of these bolts screw very nicely into the cf, btw.
So am I to assume that you guys use for bolts to connect the outer wing panel? I don't want to force them in at the moment and get me in a jam.
Thx for the help! DSA
Old 07-31-2019, 01:07 PM
  #666
Chris Nicastro
The outer wing bolts, 4 per wing, can be assembled at the field. The center wing section is bolted to the fuselage with two larger bolts and the plane can be easily transported gear up or down this way.
The round fuselage makes it hard to transport it without the center wing wing on unless you make a custom stand.
You will probably find out that you have to check the 3 outer wing bolts each flight. The 4th bolt, I call the Jesus bolt, never comes loose because it’s tightened into hard plastic and it’s pretty long. If you lose that bolt in flight and the others come loose then you get the picture. Make sure that one is installed every flight. I’ve landed with all of the bolts loose or barely tight before.
You can also file a flat where you can see the the tip of the bolts have already made an indentation. This helps make them safer from allowing the wing to slip off even if the bolt is not seated tight.
See the aluminum bulging where the bolt has deformed the spar? This makes it hard to slip the wings on/off. Go ahead and file that bulge off and make it smooth to match the spar.
Also, the threaded inserts in the wings that allow you to tighten the bolts will wear out or strip if your are heavy handed. They can be drilled out and replaced with brass self threading inserts and I have shown that on this thread.
Good luck, ask questions!
Old 08-01-2019, 07:09 AM
  #667
Dsa44
Thanks Chris! I am assuming what you call the Jesus Bolt is the 1" bolt placed on top of outer wing panel in the aft hole to secure into the CF rod? Then the 3/4" bolts go into the top and bottom holes which are more forward to secure against the metal spar?
Good idea to file down the small bump on the metal spar for cleaner fit.
Thx again, Doug
Old 08-08-2019, 01:17 PM
  #668
Dsa44
Ok, everything fits together nicely.
Prop question.... Dle55 spinning a Biela 3-blade 20x10. Is this a good combo? I read earlier that a 2-blade 22-10 was good with the dle55, so I am thinking this 3 Blade would be ok.
thx again.
Old 08-08-2019, 01:29 PM
  #669
Lifer
Lifer's Avatar
If it's a side exhaust DLE 55 it will be fine with the Beila 20x10x3. I have used that for years in the big P-40. Also use a Xoar 22x8x3 which is a little slower, but not that much.
Old 08-15-2019, 08:41 AM
  #670
Lifer
Lifer's Avatar
Chris Nicastro,
Well, I managed to strip the nylon inserts in my Corsair wing. Took 2 years! I will be installing the brass inserts per your method. Can you tell me what post number that is so I can study what you did before I begin?
Thank You!
Old 08-15-2019, 06:07 PM
  #671
Chris Nicastro
Post #582 pg 24
Old 08-16-2019, 12:01 AM
  #672
Lifer
Lifer's Avatar
Thank you! I reviewed the post and then searched Mcmaster Carr but could not locate the threaded inserts referenced in the post. Do you have a part number, or any additional guidance?
Old 08-17-2019, 12:06 AM
  #673
Chris Nicastro
Old 08-17-2019, 12:15 AM
  #674
Chris Nicastro
You can use this insert, same one I used. It has a nice coarse pitch and grips well in most materials.
I toughened up the wood in the wing and drilled it to the cylinder size of the insert, called minimum pitch diameter. Then use a short socket head M3 screw as a tool to drive the insert into the hole. It’s best to use a hex driver without a ball end. Add a drop of thin CA to bond the insert in place but don’t glue the screw used as a tool into the insert. OR, remove the screw first and then add a drop of thin CA. Either way you don’t want the insert to back out as you try to remove the screw.
Try one in a block of wood and see what’s going on. Pretty basic but good to understand.
Old 08-17-2019, 12:27 AM
  #675
Lifer
Lifer's Avatar
Thank you for the assist!
