Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
devSim Cnc Foam, a new free application
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 12-24-2016, 08:30 AM
durone
Smile devSim Cnc Foam, a new free application
I released devSim Cnc Foam, a new free application to check the GCode of a 4 axes Cnc hotwire foam cutting machine.
devSim Cnc Foam is a free application to simulate the execution of a Cnc 4 axes foam cutting job.
You can use it to preview and check your GCode files, running to job forward or rear, and setting manually the current execution point.
The 3D View will show the two carriages movement, the Foam block, and the cut surface.
The Gcode can also be listed as pseudo Gcode, translating every line in a human readable command.
You can also import a .cut file from GMFC and it will be automatically converted to GCode.
You can download it here: http://www.devcad.com/eng/devsimcncfoam.asp
If you are a Cnc software developer or reseller or you can ask to [email protected] to have your customized version, able to start and run your GCode files launching them by Run String.
Old 03-28-2024, 07:53 AM
paxjohn
I cant load cut (GMFC) files.
When I do I get the error message , to restart application . .
Pls help
Old 03-30-2024, 01:25 AM
durone
Pls help
Version 1.02a fixes that problem.
