Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Ziroli DC-3/C 47
Old 04-29-2009, 09:30 PM
gblas777
My Feedback: (13)
Default Ziroli DC-3/C 47
hey guys
any interest in a ziroli dc3 build.? have just about all the parts .this is going to be a more of a practical scale build...meaning not to much in the small scale details dept. this airplane is meant for more of an everyday flyer than a top gun competitor.it will have flaps and retracts and probably done in the c-47 military version..starting to build so should be posting some pics soon
gene
Old 04-30-2009, 06:18 AM
Stuka Jon N
My Feedback: (33)
Default RE: Ziroli DC-3/C 47
Go to it Gene. I will be following.Post Photos, Stuka Jon
Old 04-30-2009, 08:14 AM
aaflyer
My Feedback: (121)
aaflyer's Avatar
Start the build thread Gene. I am starting on its baby brother next week (TF C-47).
Al
Old 04-30-2009, 10:30 AM
gblas777
My Feedback: (13)
hey al.
i heard you were going to build one. i guess you will be going with electric on that one
question..what would you guys recommend as a good camera resolution setting for posting good pics on here?
gene
Old 04-30-2009, 04:35 PM
gblas777
My Feedback: (13)
ok i had a little time before work today to start this project so heres what i got done on the horiz stab
Old 05-01-2009, 12:00 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
Fuse breakdown and startup. I'm the project manager and wallet for this job, Thanks Bryan for the kit. My subcontractor is doing the wing while I try hacking at the fuselage. Kit was started and put away. It had some storage damage but stringers are easy to replace. Got it into the work stand and noticed a slight twist towards the tail,(probably due to storage) decided to replace all the stringers!
Old 05-01-2009, 12:05 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
How about a semi scale tail gear. Parts out junk box,Comments?
Old 05-02-2009, 11:26 AM
aaflyer
My Feedback: (121)
aaflyer's Avatar
Gene,
Your pics looks fine to me. Don't want to hijack your thread. But here a couple of pics of the TF DC-3. I just have a 5 megapixel cam. Yes going E-powered on this bird. I bought a cheap set of Forstner bits. I am drilling out every former and rib that I can. So far total weight taill group you see is 6 3/4 oz.
Al
ID:	1190651   Click image for larger version
Old 05-02-2009, 12:52 PM
SIMCO
My Feedback: (33)
SIMCO's Avatar
You could have asked Al. I have a set of Bits!!!!!!!!!!!!!!!!!!!! Brown van came and went Friday. I will have the gear Monday.
Old 05-05-2009, 04:18 PM
gblas777
My Feedback: (13)
more progress...was slowed down a little due to the quality of the sheeting included with the kit..so far i would give the laser cutting of the parts a B+ but the sheeting and some of the wood sticks get a "D". the 3/32 sheeting for the tail is very rough. had to true all the edges for edge gluing and most of the sheeting is not of uniform thickness..so spent a good amount of time truing all this up...and some of the stock for the horiz trailing edge and elev leading is warped so bad its not useable in those areas.
in the pics got the horiz sheeted and the scale hinges installed.due to keeping the tail as light as possible the hinge pin in the pics is 1/8 carbon fiber rod. so much more lighter than a steel pin.the first major mod is going to be sheeted elevs instead of open structure.
feel free AL or anybody to post pics..the more the merrier
gene
ID:	1192863   Click image for larger version
ID:	1192864   Click image for larger version
Old 05-09-2009, 03:50 AM
mozart03uk
Hi Paul Here in UK Also building this bird
do you know how the elevator servo's are positioned , are they on the stab either side
or worked from within the fuze?????
yours
hopefully
Paul
Old 05-09-2009, 04:02 AM
mozart03uk
Hi ALL
Started building the ziroli dc3 back in feb this year
here's some pics
can any one give me some info on where to install the elevater sevos
are they in the stab or are they worked from within the fuze??
any help would be appreciated
Paul
ID:	1194858   Click image for larger version
ID:	1194859   Click image for larger version
ID:	1194860   Click image for larger version
ID:	1194861   Click image for larger version
ID:	1194862   Click image for larger version
ID:	1194863   Click image for larger version
ID:	1194864   Click image for larger version
ID:	1194866   Click image for larger version
ID:	1194867   Click image for larger version
ID:	1194868   Click image for larger version
Old 05-09-2009, 07:58 AM
CK1
My Feedback: (60)
CK1's Avatar
Paul , I would mount the Elevator and Rudder servos as far forward as you can , The Ziroli DC3's tend to build heavy in the tail and usualy require a lot of nose weight .
I have mounted my servos just ahead of the trailing edge of the wing in the fuselage , and will have enough room to place the fuel tank on the CG forward of the servo's
I will try to post pics sometime this weekend.
Chris
Old 05-09-2009, 01:29 PM
ivves
Hi.
I hope my DC-3 webalbum can be to some help for You. Check it out ! http://ivves-rc.magix.net/
Regards...Ivan.
Old 05-09-2009, 01:38 PM
mozart03uk
Ah I Have seen this one on you tube splendid model way above my standard
hehe
PAUL
Old 05-16-2009, 07:53 PM
CK1
My Feedback: (60)
CK1's Avatar
mozart03uk , I finaly got to the pics and have loaded them . The elevator servos are not installed but you can see the rail system where they will be mounted ,that does have the rudder servo in place .The elevator servos will be mounted on the underside of the rails . The carbon fiber flex rods for the elevator halves are in place and can be seen in the place on each side within the fuselage
Old 05-17-2009, 02:55 AM
mozart03uk
Hi Chris
thanks for the pics, it looks great , i like the extra formers
you seem to be using the rudder servo for 2 actions ie
elevator ,and rudder is that tricky to put together,
I had a bit of a scare yesterday when i looked at the fuse standing up on its tail
and sescovered a few formers seemed out of alignment,
have rectified it now and hope the skin will sort that out.
Paul
Old 05-17-2009, 08:35 AM
CK1
My Feedback: (60)
CK1's Avatar
Hi Paul
The servo rails for the elevator and rudder are very simple to construct and install . The exact placement of the rails is not critcal . By placing them as far forward as you can you will reduce the amount of weight you will need to add to the nose of the aircraft for final balancing . The fuselage formers can be difficult to get placed perfectly in position ,but they only have to be reasonably close . The sanding of the planking of the fuselage will be able to hide any reasonable errors int placement of the formers . I built my fuselage using a jig for careful alignment of the fueslage and because of the size of the formers they tend to warp a little , this appears as a slight misalignment from various angles but the overal placement is correct .
I wouldn't be to worried if yours has the same effect.
Old 05-17-2009, 08:50 AM
mozart03uk
Hi Chris
thanks for the reply
thats a relief  the former F8 was warped considerably , its reasonable now as this one i think needs to be straight  as this  former is where the back of the wing center section will sit .
are you going to use a fiberglass nose section or built up?
i have a fiberglass nose section and was woundering if solartex would surfice using as little heat as possible perhaps
apologies for bombarding you with all these questions
but as you know there is no instruction book for this plane
which is a pitty, so any help is appreciated
thanks
Paul
Old 05-17-2009, 09:14 AM
CK1
My Feedback: (60)
CK1's Avatar
Hi Paul , I will be using the fiberglass nose section as well.I will befiberglassing all empenages and surfaces withe exception to the rudder and elevators. Fiberglassing will add structural strength and it will resist the normal dings better than a fabric covering . I would also suggest looking through the other threads here on RCU . There is great deal of information available in these threads .
http://www.rcuniverse.com/forum/m_11..._1/key_/tm.htm
Old 05-20-2009, 08:07 PM
gblas777
My Feedback: (13)
heres a little more progress....the outer wing panels are a pretty much a straight fwd build......extra care was taken when glueing the wing tubes in to get them absolutely straight and parallel......the center section shows where the fuel tanks and retract bottle will be mounted. eveything should fit inside the wing...they are 16oz tanks....one for each engine and a robart large air bottle.....enough room for all to fit inside the ribs and not interfear with anything....and last the 2 firewalls drilled for the g-38s and the relief holes cut for the spring starters..the engine is wide enough for the fuel line and throttle pushrod to run outside the firewall so it doesnt get in the way of the retracts which are mounted right behind the engines..more to come soon
gene
ID:	1202694   Click image for larger version
ID:	1202695   Click image for larger version
ID:	1202696   Click image for larger version
Old 05-26-2009, 08:17 PM
gblas777
My Feedback: (13)
a few more pics of some progress...first is with the gear mounted...pretty straight fwd and fit well.....next is with the air bottle and the 16oz fuel tanks installed...an easy fit between the wing ribs...the whole idea is to make the wing self sufficent with the only connection to the fuse is four leads for servo connections.
hows yours coming along AL. any more progress
ID:	1206718   Click image for larger version
ID:	1206719   Click image for larger version
Old 06-03-2009, 10:45 PM
Props4ever
Hey Gene,
You have great build going on here, I always wanted a nice large DC3's model and now have decided that whenever i will do a DC3 project it will be Ziroli DC3 fully decked out!. This is a great legendry bird and when i flew on it 2 years ago, it was a solid flier by all means and landing speed was 70 Knots only!!, just beautiful bird of all times. Keep it going as we will be learning from your experiances....
Cheers,
Sam
Old 06-04-2009, 08:38 PM
gblas777
My Feedback: (13)
hey sam
got a little more progress done but not much...had to get some things done around the house...hope to get a lot more done over the next few days...will post some more pics then
gene
Old 07-15-2009, 07:45 PM
gblas777
My Feedback: (13)
here is a pic of the flap servos installed.2 each for the main center flap
ID:	1237040   Click image for larger version
