Reload this Page >
Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Old 01-02-2019, 05:35 AM
  #601
rowdog_14
rowdog_14's Avatar
Ok with my cowl I it a pain in the butt to get to the cowl mounting screws. What are you guys using to mount? The Great Planes® long handle ball wrenches (GPMR8008) look to no longer be available. I went to Harbor Freight and pickup some that I thought would be long enough and they are not . Help Please
Old 01-02-2019, 06:26 AM
  #602
rowdog_14
rowdog_14's Avatar
Found a set on ebay from UK.
Old 01-02-2019, 07:06 AM
  #603
Lifer
Lifer's Avatar
Dubro sells a ball driver long enough to reach the back of the cowl. Bought mine last year.
Old 01-02-2019, 03:20 PM
  #604
Chris Nicastro
Chris Nicastro's Avatar
I started with the stock ARF method but had issues with the screws backing out even with thread lock applied. I changed to the “radial” screw method. Using the same 4 blocks I made spacers and screwed the cowl to them from the outside. Never had a problem again.
Once you add the dummy engine and if you add nose weight in the cowl the screws take a lot of load. The radial style works very well for me.
I’ve had working cowl flaps and scale dummy engines and all worked great with radial mount screws.
I was talking with a friend about RC planes the other day and realized my Corsair ARF is about 10 years old!
Old 02-23-2019, 04:39 AM
  #605
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Rebuild progress on my arf. Stripped down and fiberglassed. Scale prop, tail wheel and main gear doors operational
Old 02-23-2019, 04:50 AM
  #606
rowdog_14
rowdog_14's Avatar
Looking good!
Old 02-23-2019, 04:57 AM
  #607
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Heres a couple more
Old 02-23-2019, 05:06 AM
  #608
hairy46
Default Wow!
This is why I am a builder and you are an artist, it amazes me to see the work of others, thank you so much for sharing!
Old 02-23-2019, 10:06 AM
  #609
jagdpanther9
jagdpanther9's Avatar
that is awesome. when mine ground loops or something bad happens i plan on glassing and doing my gear doors . this is good stuff to get ideas for when that time comes.
Old 02-23-2019, 06:55 PM
  #610
Chris Nicastro
Cool, that’s what I’ve been thinking about doing to mine too. Any idea on the weight so far?
Old 03-01-2019, 10:47 PM
  #611
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Not sure..but will weigh her
Old 03-01-2019, 10:52 PM
  #612
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Update
Old 03-02-2019, 09:49 AM
  #613
jagdpanther9
which prop is that? looking awesome!
Old 03-02-2019, 12:18 PM
  #614
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Solo..22"
Old 03-21-2019, 02:26 AM
  #615
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Getting closer
Old 03-24-2019, 06:42 PM
  #616
dusturbd
droppedgmc is this the arf version and if so where did you get that cowl with open flaps and how does it fit
Old 03-24-2019, 06:47 PM
  #617
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
This is an arf and it is a fiberglass specialties cowl
Old 03-24-2019, 09:16 PM
  #618
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Complete
Old 03-24-2019, 09:41 PM
  #619
Chad Veich
My Feedback: (60)
Real nice, congrats.
Old 03-24-2019, 09:57 PM
  #620
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
Thanks..I cant get the side views to upload
Old 03-25-2019, 01:56 PM
  #621
dusturbd
So that cowl is a little larger than the stock one correct
looks great from the front how does it look from the side. The reason I ask is I am thinking of getting one so my 70 twin will fit on this bird.
thanks
Old 03-25-2019, 02:41 PM
  #622
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
The cowl is a little larger and air will flow well through it too. I'll get more pics. The ones I have will not load for some reason
Old 03-25-2019, 07:42 PM
  #623
dusturbd
Is you dummy radial the one from FS also
Old 03-25-2019, 07:57 PM
  #624
droppedgmc
My Feedback: (18)
droppedgmc's Avatar
No..it is the tf one
Old 03-26-2019, 08:30 AM
  #625
scottrc
scottrc's Avatar
Great job!!!!
